Re: Super A flooding as soon as i turn on tank valve
Posted by Dave H (MI) on May 22, 2010 at 13:16:46 from (64.12.116.73):
In Reply to: Super A flooding as soon as i turn on tank valve posted by ctallen2010 on May 22, 2010 at 10:10:31:
I know it's frustrating but you just have to get in there and calmly evaluate what is wrong. This is going to center around the needle as previously stated. Drain it, open it up, and do the checks Bob gave you. Make sure your needle is seating properly and that it is properly assembled with the float so that the float can close it. Check your float carefully to make sure it is adjusted per the manual and not leaking. It's like a boat...by definition it is not "floating" if it is submerged. You've missed something here and only careful reading of the manual and studying of your carb is going to solve it. Been there and done that! Keep at it...you'll get it.
