Farmall 200 - timing gear and crank????
Posted by RayP(MI) on May 22, 2010 at 17:20:19 from (207.241.137.116):
1956 Farmall 200 (123 engine - same as super C).
Ate the timing gear, and governor gear... Know those can be replaced, but the gear on the end of crank is showing wear, and probably needs replacement too... Is this gear removable from the crank, or is it a permament part of the crank?
Anyone got a source for recyclable timing gear and governor?
