Re: Super A flooding as soon as i turn on tank valve
Posted by bc on May 23, 2010 at 00:00:23 from (71.158.208.155):
In Reply to: Super A flooding as soon as i turn on tank valve posted by ctallen2010 on May 22, 2010 at 10:10:31:
Does you carb kit have a viton tip needle? Those are notorious for not seating well. Then if you give it too much of a tap to seat it, it will stick.
Check the surface area of the float where the needle. Sometimes a little indention forms over time and even when you set the float right, the needle rides low in the indention. Have to flatten the area out.
Brass needles are best.
Mine and others runs gas out the carb as well. The trick is to go ahead and start it, then it burns it instead of leaking and sorta fixes itself.
Personally, I wouldn't worry too much about it. That is why it is necessary to shut the fuel off on those things.
Post back with what you do.
