Re: Identify this please.
Posted by John M on May 23, 2010 at 09:12:40 from (67.231.160.184):
In Reply to: Identify this please. posted by Freud on May 23, 2010 at 07:47:15:
You poured oil in the hyrdaulics, and spilled it over the side of the fill pipe. Itll come out of that hole. Real main leak will show up there as well. I dont see how the trans shafts leaking could out of that hole, since the belly pump is in the way, it would show up behind the pump. If you have to fill your hydraulics again, use a funnel. That oil "can" get on the clutch surface and burn it up.
