Re: Click sound 560 axle/brake area
Posted by Brownie 450 on May 23, 2010 at 16:18:57 from (66.43.241.141):
In Reply to: Click sound 560 axle/brake area posted by matthies on May 23, 2010 at 09:14:37:
If all bearings are good, look into the brake housing. I guess we never had the 560 brakes apart, but if they are similar to the MTA- 450 brakes, the retracting spring [1 of 3] has probably rusted the hook off & dropped down in the housing.The clearance is unbelievably close between the discs & the casting. We pulled the bearings on the 450 when a brake spring lodged under the discs. The bearings were in good shape but the grinding/ grating noise continued. Pulled the brake housing & found the rusted spring. Worth a look.
