Broken rocker shaft
Posted by Keith LeMire on May 23, 2010 at 17:09:41 from (174.20.133.239):
Has anyone ever seen a rocker arm shaft on a Farmall M or SM broken at the thru hole where the supports are? If so is it a problem? The shaft seemed to be securely clamped in the support until I removed the bolts. I suppose it could work it's way out, but evidently it has not moved, since the tractor was running fine when I took it apart. I will replace it regardless, but I was just curious if this is a common occurrence.
