When you had the cover off did you check the condition of all the teeth on the gears? A chipped tooth can cause a tick. Maybe something laying in the bottom of the transmission that the bull gear is hitting? Make sure the bull pinion bearings are tight with no damage. Double check all wheel and hub bolts, a hub casting or axle shaft can be worn a bit and even with super tight bolts there can be enough movement to cause a noise. The clamp type castings are known for this on 560's.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
