Re: farmall m wont start?
Posted by JD2840 on May 24, 2010 at 15:47:40 from (70.118.140.97):
In Reply to: farmall m wont start? posted by Janicholson on May 24, 2010 at 10:21:14:
Zachary Hoyt said: (quoted from post at 20:51:41 05/24/10) My H did that and it was rust clogging up the elbow above the sediment bowl, so I had to drain and remove the tank, clean it out and clean out the plumbing above the bowl and put it all back together. It wasn't too bad and it's been doing fine ever since.
Zach
same thing happened on our H but we had a extra gas tank to switch it with. not that hard to take off though
