Re: High idleing H
Posted by Janicholson on May 24, 2010 at 17:03:54 from (64.61.211.122):
In Reply to: High idleing H posted by Farmallb on May 24, 2010 at 15:44:09:
If Andrew's suggestion is not working, I would worry about a loose throttle plate in the carb. It can cause erratic idle, if the screws come out entirely, they can be sucked into the cylinders and cause real problems. Before removing the carb to check it, be sure the linkage to the governor is good and free. Jim
