Re: H identification
Posted by CNKS on May 24, 2010 at 17:29:18 from (216.144.104.128):
In Reply to: H identification posted by clint evans on May 24, 2010 at 15:41:30:
It has 5th gear, it is locked out with a bolt in the front left? top of the trans cover. Not important because the H won't turn steel wheels in 5th anyway. For a 1939-42 H, the engine serial will be the same or close to the chassis serial, although IH did not attempt to match them. Otherwise use casting codes as noted. I,J,K,L are 39-42 respectively.
