Re: Farmall A Govenor problem and serial number
Posted by steve alderman on May 24, 2010 at 18:59:48 from (174.57.64.126):
In Reply to: Farmall A Govenor problem and serial number posted by Mark in Fowlerville on May 24, 2010 at 18:56:27:
on the block top right hand side towards the raditator will be some numbes FAA and some numbers and they be it
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
