Re: Put a loader on my H - it wont lift?
Posted by charles todd on May 24, 2010 at 21:08:27 from (205.242.95.131):
In Reply to: Put a loader on my H - it wont lift? posted by Faster346 on May 20, 2010 at 15:11:58:
I feel it is not getting oil to the cylinders. If you were getting oil to the cylinders, the pump was putting out, and the relief valve was cracking at the proper setpoint you would know it. Either the tractor engine would labor or the loader would lift. If neither is happening, you either have a bad pump/relief valve or no oil to the loader circuit/too little oil in the circuit. 6 quarts for a H is not much. You may have to keep adding oil to the system to fill the cylinders?
Keep us posted.
CT
