There are a number of chemical combinations that are used to clean out radiators, but I'm afraid I don't have that info. A Regular radiator isn't that difficult to disassemble, (Heat bolt heads red hot, let cool, and generally they come right out.) I'd probably diassemble the radiator, pick up a piece of brass flat stock that will fit the tubes, and run all of the tubes with it. I've done several radiators that way, and while I have them apart, I sandblast the upper and lower tanks, then coat them with gas tank sealer. Keeps them from rusting through or flaking rust.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac.
... [Read Article]
