Re: 1930 Regular radiator not circulating
Posted by VER on May 25, 2010 at 05:38:12 from (199.115.9.254):
In Reply to: Re: 1930 Regular radiator not circulating posted by James Williams on May 25, 2010 at 05:33:55:
Odd. We have a f20 as well and its never gotten nearly as hot as the regular did. If you put a temp gun on it let me know and I can do the same then compare.
I wouldn't be as concerned if the whole radiator was hot, but the top was very hot and the bottom was hardly warm at all.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
