Re: 1930 Regular carb/sucking air
Posted by Jeff Z. on May 25, 2010 at 06:11:25 from (72.228.54.208):
In Reply to: 1930 Regular carb/sucking air posted by VER on May 25, 2010 at 05:12:13:
I would check the intake manifold gasket first. I use a non-flammable cleaner and spray it around the manifold with the engine running. If there is a leak and it get's sucked in the engine will run real rough for a second.. I use a non-flammable brake cleaner.
Today's Featured Article - The Fordson F Ignition System - by Anthony West. A fellow restorer contacted me earlier this year asking for some help and advice on a model F that he was restoring. He had over a period of months spent a fair amount of his hard earned cash on replacement parts for the old "trembler" ignition. Sadly though all his efforts seemed to be a waste of time and money as he still couldn''t get the temperamental old thing to run correctly!! If i said that this was a little frustrating for him that would be "conservative" in fact the problem had reduce ... [Read Article]
