During your flushing, have you disconnected the radiator from the engine completely, then flushed the engine by itself?
With the radiator totally disconnected from the enging, and as you are filling it from the top with your garden hose, is it having a tendency to fill up on the top of the radiator? Seems a good radiator will drain more to the lower end than most garden hoses can put out. If this is not true, tube blockage, is probably at fault. The lower radiator casting is the lowest part of the system, and it could be full of rust crud that most likely won't "flush", and will have to be mechanically removed.
In the two F-20s that I did some work on, the block contained 2-4" of sludge that probably wouldn't flush out. I used a small piece of tubing that would fit down into the coolant holes on the top of the block, duct taped to a shopvac, and after some time, was able work most of it loose with a rod & vacuum it out. After then, I used a piece of copper tubing attached to my garden hose to flush the rest out the lower radiator hose fitting.
Pulling the sleeves would be easier, but did't want to do that.
Today's Featured Article - When Push Comes to Shove - by Dave Patterson. When I was a “kid” (still am to a deree) about two I guess, my parents couldn’t find me one day. They were horrified (we lived by the railroad), my mother thought the worst: "He’s been run over by a train, he’s gone forever!" Where did they find me? Perched up on the seat of the tractor. I’d probably plowed about 3000 acres (in my head anyway) by the time they found me. This is where my love for tractors started and has only gotten worse in my tender 50 yrs on this “green planet”. I’m par
... [Read Article]
Latest Ad:
[More Ads]
