Re: 1930 Regular radiator not circulating
Posted by Cameron Smith on May 25, 2010 at 09:20:26 from (24.107.239.147):
In Reply to: 1930 Regular radiator not circulating posted by VER on May 25, 2010 at 05:06:15:
Thermosiphoning cooling relies on the free passage of coolant. Any restriction in the block or radiator passage ways will cause a slowdown or stoppage of the coolant movement and make it heat up. Cleaning the crap accumulated over eighty years of usage is going to require some effort but is well worth it. Good luck.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
