Re: 1930 Regular radiator not circulating
Posted by rustred on May 25, 2010 at 09:51:05 from (74.198.148.45):
In Reply to: 1930 Regular radiator not circulating posted by VER on May 25, 2010 at 05:06:15:
same as sgtbull says, you can make new gskts. and then you know the rad is good to go.thats one thing with these rads you take em apart clean em and dont need a rad shop if the cores are good.
Today's Featured Article - The Cletrac General GG and the BF Avery A - A Bit of History - by Mike Ballash. This article is a summary of what I have gathered up from various sources on the Gletrac General GG and the B. F. Avery model A tractors. I am quite sure that most of it is accurate. The General GG was made by the Cleveland Tractor Company (Cletrac) of Cleveland, Ohio. Originally the company was called the Cleveland Motor Plow Company which began in 1912, then the Cleveland Tractor Company (1917) and finally Cletrac. ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
