Re: IH 784 shift problem
Posted by Jimb2 on May 25, 2010 at 19:47:47 from (99.240.236.11):
In Reply to: IH 784 shift problem posted by Koehn on May 25, 2010 at 10:18:42:
Hi Koehn, a few things to check out:
Is the Hi/Lo/Rev linkage worn and sloppy?
Has the sheet metal around the shift levers been bent or mispositioned.
There are adjustments on the shifter rods. Sometimes the shifter lever that goes into the transmission case can become twisted or even snap off.
The next time it appears to pop out of gear try pushing it into gear without touching the clutch and listen for gears grinding. If there is no gears grinding then maybe it is the T/A disengaging. My brother has a 684 and the T/A would unlock on it. Sometimes to get it going again had to put Hi/Lo/Rev in Neutral depress and release clutch a few times and then it would work again. We had replaced the clutch about a year before. He had the T/A replaced with an eliminator shaft. That fixed the problem.
Hope this helps
JimB
Today's Featured Article - Harvestin Corn in Southern Wisconsin: The Early Years - by Pat Browning. In this area of Wisconsin, most crops are raised to support livestock production or dairy herds in various forms. Corn products were harvested for grain, and for ensilage (we always just called it 'silage'). Silo Filling Time On dairy farms back in the 30's and into the first half of the 40's, making of corn silage was done with horses pulling a corn binder producing tied bundles of fresh, sweet-smelling corn plants, nice green leaves with ear; the ... [Read Article]
Latest Ad: 2022 John Deere 5045E, 4wd, front end loader and 3rd function with grapple. 120 hrs, 55k new, must sell [More Ads]
