Had the same problem on new holland compact yanmar 3 cylinder it might have the same clutch setup, It was rust, they use a straight shaft for the clutch pedal but use a hollow tube for the throw out bearing fork which slides over clutch shaft I believe it was held together with a roll pin inside which gave way. The fork shaft slipped enough to still bring the pedal back but not enough to release the clutch. take the clutch release arm off and rotate it with a pipe wrench in the direction of release and see how much farther the shaft rotates or try extending the adjuster.
Today's Featured Article - Earthmaster Project Progress Just a little update on my Earthmaster......it's back from the dead! I pulled the head, and soaked the stuck valves with mystery oil overnight, re-installed the head, and bingo, the compression returned. But alas, my carb foiled me again, it would fire a second then flood out. After numerous dead ends for a replacement carb, I went to work fixing mine.I soldered new floats on the float arm, they came from an old motorcycle carb, replaced the packing on the throttle shaft with o-rings, cut new ga
... [Read Article]
Latest Ad:
Nice Marvel Schebler DLTX 8 bronze body carburetor For 1934-1936 unstyled A tractor.Serial No.410000-42850. All restored and ready to use.
[More Ads]
