Re: Restoring ammeter/light switch to original
Posted by Firechief135 on May 26, 2010 at 06:27:52 from (156.142.4.44):
In Reply to: Restoring ammeter/light switch to original posted by Firechief135 on May 25, 2010 at 15:56:34:
Janicholson,
Thank you for your reply. I will have to look at the tractor this weekend - it is about 200 miles away from where I normally live.
It is a 12 volt negative ground and I am pretty sure (showing some ignorance here) that is a distributor system. I will check the number of connections on the generator and VR too.
One question - why is the push/pull ignition switch different for a magneto vs. a distributor?
Thanks again so much for your help.
Brad
