Posted by rustyfarmall on May 26, 2010 at 07:19:57 from (209.152.78.140):
In Reply to: high ideling H posted by Farmallb on May 26, 2010 at 06:02:58:
Farmallb said: (quoted from post at 06:02:58 05/26/10) I backed off the screw underneith the govenor tube, But didnt make a difference. Will check choke plate for looseness. It runs perfectly. Pulled a IHC wing disc without the wings, but with RR ties in the weight brakets, no problem
I think you need to completely remove the carburetor. Inspect the ears on the throttle shaft, and inspect the little tang on the shaft coming from the governor, and while you are looking, make sure the throttle plate is still attached securely to the throttle shaft. If all of those things check out, then it is time to remove the cover from the governor and have a look inside.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
