Re: Super C stuck
Posted by MurrayE on May 26, 2010 at 17:02:19 from (99.192.58.45):
In Reply to: Super C stuck posted by hayhayler on May 26, 2010 at 07:22:44:
Hi, There are two attempts that you can to loosen your engine and won't cost any money. First attempt as everyone has stated is take out the plugs and put in a couple of spoonfuls of some type of penetrating oil. If you have a crank put that in place as though you were going to crank/turn over the engine, place it at the 1:00 A.M./ P.M. position and hang a 5 gal bucket on the handle of the crank. Then fill sand or rocks in the bucket to give it weight. Let it set for a few day's. The other attempt is to place the penetrating oil in the cylinders, jack one wheel off the ground, after it has sat for a few day's, place transmission in highest forward speed and try moving/rocking the wheel that is off the ground. Be careful as the politically correct will and it can happen strip a timing gear. The above worked good for me and the engine run's great. It had previously sat in an old barn for a few years. Cheers, Murray
Today's Featured Article - Allis Chalmers ED40 - by Anthony West. Allis Chalmers as a tractor manufacturer in its own riht is but a memory. However the number of AC tractors still in existence today as either restored or unrestored examples is a testament to the quality of their products. This in itself is always apparent here in the U.K when attempting a purchase, as no matter what the model or condition the price will always be strong. ... [Read Article]
