A good inferred thermometer can be bought for $60 to $90 from most auto parts stores and makes an excellent diagnostic tool for cooling issues. Don't count on your tractor guage to read correctly. Measure the coolant temp at regulator and top of tank (should be similar) and then measure at bottom radiator return (should be 30 to 40% cooler than inlet). If little difference in temperature, the radiator may be plugged, the waterpump is not moving the coolant, or the thermostat may be stuck closed. I have an H that had a waterpump failure. The the shaft broke loose from the impeller, then the shaft moved forward until disconnecting from the drive pins.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
