Re: SMALL WATER LEAK IN OIL ? WHAT HELPS
Posted by IndianaRed on May 26, 2010 at 17:15:25 from (75.46.78.113):
In Reply to: Re: SMALL WATER LEAK IN OIL ? WHAT HELPS posted by mkirsch on May 26, 2010 at 05:03:56:
You know, that's what I've always thought too. But my Chevy had the all to common intake gasket desentigration. Was loosing over a quart every few days, (driving 250+ miles a day). I was all ready to pull the top off and switch the gaskets out when a friend told me to try those cheap little $2 brown tablets that come in six packs. Cruched them all up, poured them in and the leak stopped. Been holding since last summer with no coolant loss, to my utter surprise. Not saying they would work in all situations. And I wouldn't have believed it if it hadn't worked for me. Probably just got lucky. I also switched from the GM pink to green. Read a lot of arguments over wether it is caused by the DexCoolant or bad gaskets.
