Re: 3pt 895
Posted by Jimb2 on May 26, 2010 at 20:39:25 from (99.240.236.11):
In Reply to: 3pt 895 posted by john895 on May 26, 2010 at 14:48:18:
Hi John, here are a couple posts from archives that maybe helpful.
3 pt hitch not lifting, other hydraulics work OK:
Hi, under the seat is the unload valve with a big plug in front. Remove the plug and pull the spool, make sure to replace in the same way. It has a small orifice, blow out with air. Replace the spool then the plug. Start the engine and check the lift system. Bernard le mécano Québec Canada
Hi, in the unloader valve it has a spool with a orifice, may be it have a dirt in the small hole. To make a test, loose the big plug, in front of the unloader, for two turn and run the engine and raise the hitch. If it works, check the spool.
