Hi Joe, below are a couple articles from archives about flow divider/splitter valve by Bernard le mécano: The flow divider becomes stuck on the plug end when you turn the steering until relief valve activates. Remove the big plug below the hydraulic filter, remove the flow divider valve and spring, make sure to replace in the same way. The end that stops on the plug is round and square, with a steel saw, make a small groove in the end of the flow divider. That will stop the suction lock, when the valve hits the plug.
The priority valve allows 3 gpm to the steering system. Below the hydraulic filter, it has a big plug, the valve is in that hole. Remove the plug, remove the spring and maybe the valve is stuck all the way up or down. With a fine emery cloth, remove all scratches on the spool until it moves freely in the hole.
Fix for MCV Power Steering flow divider: CIH has a parts kit to replace the flow divider valve, in the MCV. It's a sleeve with a spool in it. It will fix your steering problem. Check with a CASE-IH dealer. Bernard le mécano
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
