Re: 450 diesel pump
Posted by M Diesel on May 27, 2010 at 18:14:52 from (70.173.91.228):
In Reply to: 450 diesel pump posted by 450dieselfan on May 27, 2010 at 14:56:01:
Well, presuming the seal is actually working and you got both the thin and thick gaskets back in place with no isues, then it would be back flowing in from the tank return line. That isn't real likely, due to the long standoff pipe inside the tank on the return fitting as well as the pressure relief needle valve being in the way inside the pump. But if the stand pipe is broken/corroded and the needle seeps well then maybe...
There may be something I'm forgetting, but I consider those to be the most likely. Otherwise the plunger assembly has a leak, and that would also require some needle valves to leak as well.
Today's Featured Article - Farmall 460: That's My Girl - by LeAnn R. Ralph. How many sounds can you think of that are as familiar to you as your own breathing? What about the hum of your refrigerator? Or the thump of your clothes dryer? Maybe the engine of your car? You hear those sounds every day, and you don't think much about them, do you. I can think of a few common, ordinary sounds in my daily life, too. ... [Read Article]
