Re: SA Steering Control Arm Removal
Posted by Janicholson on May 27, 2010 at 18:46:55 from (64.61.211.127):
In Reply to: SA Steering Control Arm Removal posted by Doug Kieta on May 27, 2010 at 18:32:29:
Though it is a struggle, it is good that it is tight, many come loose and cause dramatic looseness at that point. A torch to heat the outside of the joint to beyond touchable, but not roasting the grease, a puller that will reash under the arm, and or a solid strike with a drift punch and 2 pound hammer on the side of the joint is what I use. Jim
