Re: Radiator overflow part 2, with pictures
Posted by M Diesel on May 27, 2010 at 20:39:52 from (70.173.91.228):
In Reply to: Radiator overflow part 2, with pictures posted by Zachary Hoyt on May 27, 2010 at 18:58:59:
Zachary Hoyt said: (quoted from post at 18:58:59 05/27/10) Should I be able to see by looking at the old gasket if it had a leak? I have a notion that the leak makes a stain on the gasket, but I can't recall the details. Thanks very much.
Zach
Not necessarily. Before you pull any head bolts, use a torque wrench on the head bolts to check tightness. Often times they were never re-tightened and over the years the gasket finally lets go because it isn't being held down. (That problem is an old Fel-Pro specialty. Too thick and too soft.)
