Re: 560 IH hydraulics
Posted by pete 23 on May 28, 2010 at 10:48:47 from (173.87.144.56):
In Reply to: 560 IH hydraulics posted by Ed Dibling on May 28, 2010 at 03:32:28:
If you can maintain that 1400 psi at the pump when trying to lift the bale that would indicate the fluid is blocked some where. Most likely place is a quick coupler return male coupler. If you have 7/8th straight o-ring type hose ends you could take couplers off and hook direct into outlets to check. Some of them old couplers used on the 560 screwed apart so you could hook under pressure and sometimes they will back out a ways and block flow.
