Posted by M Diesel on May 28, 2010 at 10:52:39 from (12.24.61.12):
In Reply to: 450 diesel pump posted by 450dieselfan on May 27, 2010 at 14:56:01:
Well, if it is, you can find out by blowing through it.
Heres the questions to ask. Does it fill just sitting? Does it fill when running? Or both?
The A and B pumps handle fuel somewhat differently although they are nearly identical. Both have a pair of needle valves to regulate pressure, one inside the primary pump, and another at the inlet to the plunger assembly. On the A, pressures are set to 60 and 75, meaning that the primary pump handles regulation by venting at 60 psi back to it's own input. On the B, pressures are set to 75 and 60, meaning that the plunger inlet handles regulation. With no scavenger pump to pick up the excess, it vents out the back into what becomes the tank return. That is why the return line is up there on top coming out the back side of the plunger assembly.
Both pumps assume that leakage from the plunger and distributor valves will dribble into the bottom somewhere. The A routes this to the backside of the primary pump (it is a dual pump) via the scavenger valve and sends it back to the tank. The B assumed that the pump internals didn't leak enough to matter and just dump it overboard. Obviously when worn, things change.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
