Re: Need opinion on oil soaked brake bands
Posted by wayne in mn on May 28, 2010 at 14:35:29 from (24.179.175.173):
In Reply to: Need opinion on oil soaked brake bands posted by Tom Fleming on May 28, 2010 at 12:46:59:
After installing the bands & getting the pedal free-play to about 1", apply the brakes firmly, lock them in place and adjust the set-screw on the bottom side of the cover. (helps to loosen any adjustable parts BEFORE re-assembly) Loosen the jam nut, turn the set-screw in until it touches the brake band, back out 1/2 turn & lock the jam nut. This helps prevent the brake band from dragging, premature wear, and overheating.
