Re: Super C, Brace between front end and bell housing.
Posted by Janicholson on May 28, 2010 at 18:06:36 from (64.61.211.197):
In Reply to: Re: Super C, Brace between front end and bell housing. posted by DFZ on May 27, 2010 at 15:51:50:
Good idea and I would just keep servicing the cleaner as you are. There are many Small frameless Farmalls with welds, and plenty of unusable blocks as well. Jim
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
