Re: farmall H hydra won't lift mower
Posted by Zachary Hoyt on May 29, 2010 at 07:42:48 from (184.8.252.211):
In Reply to: farmall H hydra won't lift mower posted by point3dave on May 29, 2010 at 06:58:18:
The reservoir for hydraulic fluid is part of the pump unit. If you look on the right side of the tractor under the gas tank you'll see a pipe sticking up with a cap on top. There was originally a dipstick under the cap but most have fallen out over the years. If I recall right it is supposed to be 6" or 8" down from the top of the neck or something like that. Have you checked on the pump driveshaft to make sure it's turning?
Zach
