Re: Farmall A Cultivator
Posted by gene bender on May 30, 2010 at 01:46:55 from (67.55.226.67):
In Reply to: Re: Farmall A Cultivator posted by Stuart on May 29, 2010 at 21:37:33:
You must have either the 136 or the 138. The 136 has pipe where the shanks fit as the 138 has a solid rectangle bar where the shanks fit. Now are there two seperate pieces with one shank on each as they go on the rear to cover the tractors track with a long piece of a flat bar with a curve that picks them up when the cult is raised. Where is your location.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
