Re: Farmall 140-Cut off won't start...HELP
Posted by El Toro on May 30, 2010 at 04:31:23 from (74.103.74.58):
In Reply to: Farmall 140-Cut off won't start...HELP posted by Mountaineer_doc on May 29, 2010 at 20:47:54:
Pull the gas line at the carburetor and see if there's full stream of gas to the carburetor. If there's just a trickle you have blockage between the tank and carb. Look in the tank with a good flashlight for any crud in the tank blocking the outlet.
Squirt some starter fluid around the throat of the carb. If it doesn't fire you need to pull off a plug wire and see if there's fire to your plugs. You will need a helper to do this. You need your ignition on too. If there's no fire I would clean the points. You need to make sure battery voltage is at the coil. With the points open you should have battery voltage on both small terminals with the switch on. Hal
