Re: 1951 farmall super c plows
Posted by IH fan on May 30, 2010 at 06:20:55 from (70.244.99.105):
In Reply to: 1951 farmall super c plows posted by Ed Hotaling on May 30, 2010 at 05:23:01:
There was a mounted plow made for the C and SC without the fast hitch... don't know the model number. A mounted plow pulls easier than a pull type due to the weight transfer of a mounted plow to the tractor. Dad had both a Fast Hitch and a C mounted plow at different times, and other than being more of a PITA to mount, he said the C plow worked better. I don't know from personal experience as the Fast-Hitch plow is the only one I ever used. The C mounted plow uses the "Touch Control" lift arms to raise and lower it. If you add the Fast Hitch, you also need the auxillary hydraulics valve in addition to the actual F-H parts.
This post was edited by IH fan at 06:22:17 05/30/10.
