Re: how much is this h worth
Posted by CNKS on May 30, 2010 at 06:46:03 from (216.144.104.128):
In Reply to: how much is this h worth posted by Drewbee90 on May 29, 2010 at 19:50:52:
Sounds like someone merely replaced the parts it needed and nothing else, and painted it. Painted to sell does not work with me. $1500 max.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
