I do not know which pump you have, so I will recommend two things. I would put a relief valve in it, on the pressure hose. I would probably purchase a set of valves with an adjustable pressure relief built in (set to 1200psi). I would not use the belly pump for a reservoir as it is below the level of the pump, and makes priming difficult. I would purchase (or fabricate) a reservoir of about 8qts. or so. The valving could be for either single acting or dual acting cylinders, with the return to the reservoir. I would continue to use the belly pump if it is operational, as it would give me more options. I would use hytran in the new system as well as the belly pump. Jim
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
