You begin by setting the static start timing so she will start, which is pretty close to fire right at or near TDC, and then the distributors spark advance mechanism (mostly centrifugal) determies tha advance versus RPM to match the engine and its compression etc.
Timing specs for distributors often say set it for x advance at x RPM and you can do that with a timing light butttttttttt remember when youre rotating that distributor youre ALSO affecting the static start timing.
If I have no manuals (the usual case lol) I set the initial static start timing first by getting the No 1 piston to TDC and adjusting the distributior so right there she fires. Then she should start and use a light to see where she fires as RPM is advanced and if its close I let her go or perhaps tweak it a bit but not so much the start timing is way slow or fast. It also depends on if its a hand crank or an electric start, the hand crank isnt very forgiving, one dont like kickback from too fast timing while too slow makes them hard to start. An elec start is more forgiving up to a point.
Today's Featured Article - Oil Bath Air Filters - by Chris Pratt. Some of us grew up thinking that an air filter was a paper thing that allowed air to pass while trapping dirt particles of a particles of a certain size. What a surprise to open up your first old tractor's air filter case and find a can that appears to be filled with the scrap metal swept from around a machine shop metal lathe. To top that off, you have a cup with oil in it ("why would you want to lubricate your carburetor?"). On closer examination (and some reading in a AC D-14 service manual), I found out that this is a pretty ingenious method of cleaning the air in the tractor's intake tract.
... [Read Article]
Latest Ad:
[More Ads]
