Re: SH missing
Posted by Matt896 on May 30, 2010 at 16:56:43 from (74.70.76.26):
In Reply to: Re: SH missing posted by pat in wis on May 29, 2010 at 22:26:10:
before you start replacing things i would pull of the plug wires 1 at a time and see if its just one cylinder or if all of them are doing it... you may have a stuck valve in one cylinder or a broken valve spring.
if it seems to be in all cylinders then i would lean toward something more common like the cap, rotor or coil. those coils can go bad from time to time and cause pretty bad misfires.
