Re: farmall m live hydraulic hook up
Posted by mkirsch on May 30, 2010 at 18:34:34 from (67.253.216.24):
In Reply to: farmall m live hydraulic hook up posted by a bartholomew on May 29, 2010 at 20:45:09:
Regardless of which live pump you have, it plumbs basically the same way.
You can use the belly pump as a reservoir only. None of the belly pump plumbing or valving is used.
You hook a hose from the drain on the bottom of the belly pump to the intake on the pump.
You hook a hose from the output on the pump to the in port on an open-center two-way valve.
You run a hose from the out port on the two-way valve to the fill pipe on the top of the belly pump.
That's pretty much it. Make sure the two-way valve has an adjustable relief valve built-in.
