Re: Re: Farmall M lost gears
Posted by Bart on May 30, 2000 at 15:39:24 from (209.91.32.95):
In Reply to: Re: Farmall M lost gears posted by Big Diesel on May 30, 2000 at 04:01:43:
Hey Big Diesel, That easy fix didn't work. I turned the nut clockwise as you look straight at it. Wrong way? I suspect there is some linkage problem on the clutch side. The PTO does work ok. So does the hydraulics from lift all. Next step is to drop the lift-all and check the clutch, like I know what I'm looking for, Duh. Thanks again, Bart in Vt.
Post A Followup
: Re: Re: Re: Farmall M lost gears
