Re: timing or distributor question
Posted by Owen Aaland on May 31, 2010 at 00:04:13 from (65.165.246.132):
In Reply to: timing or distributor question posted by Machine249 on May 29, 2010 at 18:10:47:
The electric shut off solenoid on the carburetor main jet was developed to correct this problem. Without a positive fuel shut off in the carburetor fuel continues to be drawn into the engine as it spins down after the ignition is turned off. Hot spark plugs will cause the engine to continue to run . The backfire is caused by fuel passing through the engine and entering the muffler where it ignites. Letting the engine cool down a couple of minutes before you turn it off can help eliminate the problem
