Super C leaking hyd fluid into mtr struggling with archives
Posted by Dean Olson on May 31, 2010 at 08:19:26 from (76.31.42.124):
I have a farmall SC that is leaking hydraulic fluid into the motor. Because I read these forums for fun I knew exactly what was going on. Pump works great other wise. After every use I put in a couple cups of hydraulic fluid and open the top oil check valve in the oil pan and drain the excess. It's time to fix it now and I can't find the posts that address this more clearly. I want to know what the part # is for the front seal. If my pump shaft is scored what's the process is for getting a speedy sleeve installed. Any advise on how retrieve posts from the archives would be great.
