I would pull the nozzles and have them checked and rebuilt if necessary. Relatively easily done but isn't altogether cheap. Checking the fuel pump is more tricky because you need to get in correct time when replacing it. Similar to issues when removing and installing a distributor. Having someone work on a fuel pump can be expensive. It is possible but unlikely that your compression is low and the engine needs to be rebuilt. I certainly would throughly check the fuel system before even considering this as a possibility.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
