Your white smoking under no load over 1500 rpm is an indication of the automatic advance not advancing far enough or static timing too late. Need a window on pump to observe automatic advance while running. Fuel pressure is critical on that which would mean you have to have a full flow of fuel to pump through clean filters for starters and proper fuel pressure which is adjustable on those pumps. Lot easier to check than nozzles and very little expense. Realize of course those engines are prone to slow cleanup of exhaust expecially if they still have the low compression pistons in them and possibly valves have been ground to lower valve protrusion and of course comp ratio.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
