Re: super a thrust bearing in pices, idling problems
Posted by athol carr on May 31, 2010 at 17:54:20 from (132.181.71.211):
In Reply to: super a thrust bearing in pices, idling problems posted by ctall2010 on May 31, 2010 at 15:13:21:
I had an O-12 with all the governor thrust bearing balls in the bottom of the sump, the bearing cages had disintegrated after a bearing further up on the rock-shaft failed after someone brazed the shaft together after it had broken
