just a thought, have you ever greased the pilot bearing? the flywheel should be drilled for a zerk fitting. on the m (should be the same for the h) you rotate the engine around, there will be two timing notches close together, and then one all by itself. line the single one up with the pointer and then look up into the drain hole on the bottom of the bell housing. you should see the zerk ther. give it 2-3 pumps of grease, not too much or it will leak out on the clutch disk. if you dont have a single notch, have a helper slowly hand crank the motor around and peek up thru the hole with a flash light to find the zerk.
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
